![]() | Home > Maintenance & Modifications > RRS SPORT 2005 STEERING GONE STIFF HELP REQUIRED.. |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
I would start by jacking the car up and looking for any tightness in the system before launching into replacement pumps.
htc Member Since: 10 Jan 2016 Location: beds Posts: 15 ![]() ![]() ![]() |
Had the same symptoms on my car 6 months ago.
Lyonhead Member Since: 21 May 2016 Location: Cardiff Posts: 351 ![]() ![]() |
Had a similar issue with my 2010 RRS Supercharged where the steering wheel wasn't returning to centre on its own after turning corners,if you know what I mean just seemed stiff in operation.
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 ![]() ![]() ![]() |
Thanks for the replies.
Lubricate everything first, certainly be the cheapest option.
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
My money is on the issue being the lower steering column UJ and the powersteering fluid has never been changed since new. |
Hocks172 Member Since: 01 Dec 2016 Location: Brighton Posts: 84 ![]() ![]() |
I agree with Socast, i had the same symptoms on my d3 and it was the lower steering arm seized nearly solid!! |
tone 123 Member Since: 18 Dec 2014 Location: northeast Posts: 36 ![]() ![]() ![]() |
I had the same problem UJ. sprayed with WD40 fixed problem but will need new one. |
