![]() | Home > General (L494) > Incontrol remote start and apps question |
andymc Member Since: 04 Jan 2017 Location: london Posts: 127 ![]() ![]() |
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 ![]() ![]() ![]() |
I do not know if it is a SIM Card or some other type of card, but, there is definitely some form of communication system built into the car.
DavidHem Member Since: 07 Oct 2016 Location: Warwickshire Posts: 38 ![]() ![]() |
Thanks for the replies, since looking into this more closely, there is a sim card built into the car for use with the remote apps etc and call assist, as mentioned, the owner installed sim card is just for car to be connected to the internet for map updates, hotspot wifi etc. |
I have a slightly different question about the same app.
wokkaman Member Since: 08 Nov 2006 Location: GU34 Posts: 761 ![]() ![]() ![]() |
i have the same question over the remote start... do you have to add the stupidly expensive option? GONE** RRS 3.0SC Silver fully loaded |
As far as I know, you should get access to the remote start etc for 3 years from new, and the subscription can then be renewed, andymc, I would contact LR support or go back to the dealer as you should have remote start. |
GJW1 Member Since: 19 May 2015 Location: UK Posts: 447 ![]() ![]() |
Only the MY17 has the engine start in the app. The MY16.5 and before only had remote heat and no start unless you had the remote park heat upgrade at £1000 extra. I actually have remote heat which doesn't start the car and engine start as I have the heater on MY17. Personally this was £1000 I didn't need to spend but this is the problem when you don't know what a MY17 will do when its first published. I assume other MY17 owners cant set up daily warming and starting the car is probably a lot more fuel hungry than the fuel heater. |
Hedders007 Member Since: 19 Mar 2015 Location: Sussex Posts: 86 ![]() |
My car is a MY16, and I did order the Park Heater.
