![]() | Home > Maintenance & Modifications > Lumpy Rough TDV8 Engine - Newbie needs help! |
Get the codes read which might show where the issue is.
Agree that reading the fault codes is the logical starting point.
cue_ball80 Member Since: 15 Jan 2017 Location: Fareham Posts: 9 ![]() ![]() ![]() |
Well now that is impressive Paddi!
Ok - sit rep! Oil temp sensor replaced... No change at all!
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4455 ![]() ![]() ![]() |
Check the injector live values |
Fault codes read on Monday (apart from the odd electrical gremlin signal fails to speed control module and terrain control module which all work 99.9% of the time) were...
Mark is a highly rated chap in the area |
I agree - Mark @ West 4x4 is fantastic! He's been really helpful through my fault finding.
Interesting thread. Something seems very odd though. If the EGRs are faulty, would the engine run normally when cold or up to full temperature? Still sounds like a problem with incorrect fuelling possibly due to the engine ECU receiving false information about temperature during the warm-up phase.
Well took a trip to Avon Tuning today (2hrs each way but they have done over 50 EGR deletes on TDV8's in their time and produce their own EGR blanking plates from laser cut sheets).
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
Looks like you've seen the last of your issues, great result. If you don't mind, what was the cost for the EGR delete? |
delta351 Member Since: 10 Jan 2017 Location: Fareham Posts: 84 ![]() ![]() ![]() |
Glad you got it all sorted cue_ball80, I live in Fareham too I may see you around! 2006 RR Sport Supercharged Love this car
Cost £300 to blank off and alter software - cheapest EGR replacement (changing both together using genuine parts) was £815inc VAT. I see that as a £515 saving and never having any EGR related problems ever again, plus better fuel consumption so can't be a bad thing!
