Home > Maintenance & Modifications > Lumpy Rough TDV8 Engine - Newbie needs help! |
Good to hear it is running well. I've been put off trying the same thing after seeing the comment from our ever-helpful contributor Disco_Mikey in this thread quite recently:
Fri Jan 27 2017 5:15pm |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
Thanks, a trip to Bristol required then. That's a good price to get rid of a potential issue down the line. Mine is in for a service on Tuesday so will make an appointment with Avon once this has been done. |
Fri Jan 27 2017 6:53pm |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 311 |
Is that based on actual fuel consumption at the pump, or what the dash is saying? If it really is such an improvement, its probably worth it for economy alone, but Im wondering if the software patch has messed up the calculation of the dash readout. |
Sat Jan 28 2017 6:53pm |
cue_ball80 Member Since: 15 Jan 2017 Location: Fareham Posts: 9 |
It's a combination of both - obviously I haven't exactly filled up much in under a week but the fuel needle isn't dropping as fast as it used to and the range till empty drops more realistically rather than going down about 3 miles for every mile driven like it used to. My issue with the EGR's was throwing off the engine and so it was running very poorly and very rich (if you were outside the car the diesel fumes could make your eyes water). Therefore I have probably gone from terrible consumption due to poor running back to only a few MPG more than most standard well running engines will get- so obviously for me the difference was huge. |
Sun Jan 29 2017 4:50pm |
