Home > Maintenance & Modifications > Kent area iid tool required
Wayneclarke
Hi guys,
Anyone in the Kent area fancy checking my FBH think it's locked out again and needs unlocking ?
Post #514408 Fri Jan 13 2017 8:33pm
Didn't I read you could remove the fbh fuse for a few minutes and this would clear the lockout.
Post #514411 Fri Jan 13 2017 9:06pm
Wayneclarke
yeah i read the same somewhere but then also I'm sure it said that doesn't actually work ? if it does great job
Post #514413 Fri Jan 13 2017 9:39pm
RobP
No doesn't work if locked out TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #514417 Fri Jan 13 2017 11:15pm
Wayneclarke
How did you get yours unlocked Rob ? And where ?
Post #514418 Fri Jan 13 2017 11:17pm
RobP
Just replied to your PM if you need someone with IId tool then Geoff on D3 forum is your guy
http://www.rrsport.co.uk/forum/member-geoff-2.html TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #514419 Fri Jan 13 2017 11:17pm
