Home > Maintenance & Modifications > Kent area iid tool required |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
Didn't I read you could remove the fbh fuse for a few minutes and this would clear the lockout. |
Fri Jan 13 2017 9:06pm |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 |
yeah i read the same somewhere but then also I'm sure it said that doesn't actually work ? if it does great job |
Fri Jan 13 2017 9:39pm |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
No doesn't work if locked out TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Fri Jan 13 2017 11:15pm |
How did you get yours unlocked Rob ? And where ? |
Fri Jan 13 2017 11:17pm |
Just replied to your PM if you need someone with IId tool then Geoff on D3 forum is your guy http://www.rrsport.co.uk/forum/member-geoff-2.html TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
