Home > Technical > Inlet Manifold TDV6 |
Sirrel Squirrel Member Since: 16 Jun 2014 Location: Essex Posts: 25 |
All fixed, luckily the garage was able to clear out the DPF, phew! |
Fri Jan 13 2017 12:10pm |
RRSporter Member Since: 08 Nov 2012 Location: UK Posts: 61 |
This did come apart Optimism was unfounded. Have just had the 'pleasure' of fitting new manifold. Anyway all sorted 3.0 SDV6 HSE L494 |
Thu Mar 16 2017 11:29pm |
TrafficMan Member Since: 01 Nov 2020 Location: Nottingham Posts: 8 |
Started the replacement of both Inlet Manifolds on my 2011 RR Sport TD V6 HSE.
Fri May 21 2021 8:49pm |
Yes I’m afraid so. Def did for drivers side. Most awkward access to get these off. Also fuel cross pipe at rear v difficult to get off as I recall.. Good luck! 3.0 SDV6 HSE L494 |
Fri May 21 2021 10:14pm |
