![]() | Home > Technical > Actuator sticking |
Farmer Mel Tucker Member Since: 10 Dec 2016 Location: South West Posts: 34 ![]() ![]() ![]() |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Yes that good |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
Hi it was wurth high temperature penetrating oil off eBay 18£ a tin
What kind of use does your vehicle get? If it is all mostly short journeys and run on standard diesel or worse the budget supermarket stuff, perhaps the variable vanes themselves inside the turbo are partially seized with carbon deposits. You could try putting a few tankfulls of Shell V Max through it with some Miller's diesel cleaner added and taking it for a few long blasts to give it a clear out. I have desisted from making the clichéd accusation of using red diesel in it as I'm sure you wouldn't dream of doing that. ![]() ![]() |
Cant hurt can it Paddi. At the moment I don't do too many journeys as I work seasonally - March to October.
