Home > Faults & Fixes > CAN ANYONE HELP LOSS OF POWER BUT NO WARNING LIGHTS
manny1970
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
HI GUYS
CAN ANYONE HELP I HAVE NOTICED THIS PROBLEM GET WORSE AND VERY QUICKLY IT HAPPENED A FEW WEEKS AGO, JUST THE ONCE BUT YESTERDAY IT HAPPENED 10 OR MORE TIMES MOSTLY GOING SLOWLY LIKE APPROACHING A ROUNDABOUT ....YEP NOT BEST OF TIMINGS AS IT LOSES POWER JUST AS YOUR GOING TO PULL OUT THEN 2-3 SECONDS LATER SHOOTS FORWARD, I HAVE TRIED IT IN PADDLE MODE AS WELL AND LOSS OF POWER STILL HAPPENS, THE LAND ROVER TECH GUY RECKONS ITS ELECTRICAL UPDATE NEEDED ON GEARBOX???
WONDERED IF ANYONE ELSE HAS GONE TROUGH THIS?
SORRY BOUT THE CAPS HALF WAY THROUGH THIS POST WHEN NOTICED.
Shocked
MANNY Big Cry Big Cry Big Cry
Post #510063 Mon Nov 14 2016 5:49pm
laytonanthony
United Kingdom 2006 Range Rover Sport TDV6 HSE Stornoway Grey
I have a similar issue.
Did you manage to sort it out?
Kind regards
Anthony
Post #512917 Sat Dec 24 2016 4:21pm
Tim in Scotland
I have replied to Anthony's post elsewhere on the forum but here is something similar and the fix - http://www.rrsport.co.uk/forum/topic46283.html 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #512918 Sat Dec 24 2016 4:22pm
jason-nike
Had a similar problem on mine.
Blanked the EGR and car was back to normal, full power
Post #512982 Mon Dec 26 2016 10:17pm
laytonanthony
Mines been mapped with an EGR delete but I haven't blanked the egr off. Would this cause the same problem?
Kind regards
Anthony
Post #512984 Mon Dec 26 2016 11:36pm
Bodsy
Site Sponsor
It amazes me how many people have theirs mapped with the "EGr delete function" but then don't bother blanking it....
The version of egr delet you have, is probably just a deletion of a load of fault codes, this is the easy way that most generic remappers do it..... Rolling Eyes
Additionally, if yours is 2006, it makes no difference other than deleting codes you need!
But if you've not had the egr blanked, then you will still get the same problem if it gets stuck open. Additionally, you really should remove the centre butterfly valve as when that closes to activate the egr air flow, if there is no air for it to take, it might start sucking up oil or causing a vacuum elsewhere.
I only ever apply the EGR delete to vehicles years that actually need to have it and it is done in a completely different way, so you still know when you have faultcodes that need to be addressed.
Get it blanked fully would be my recommendation. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #513044 Wed Dec 28 2016 11:28am
laytonanthony
Went out to car this morning and struggled to start. Had to feather the throttle. I think it's the egr valves. Engine is being choked and flaps must be stuck open. Orders the blanking kit. Will post once I've fitted
Kind regards
Anthony
Post #513049 Wed Dec 28 2016 12:39pm
laytonanthony
Egr banking plates solved the problem.
Kind regards
Anthony
Post #513136 Thu Dec 29 2016 5:48pm
