Home > Maintenance & Modifications > RRS front suspension bushings question - Help |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 |
Suspension bushes were replaced on mine last year under warranty and were picked up as advisory again this mot, so it is booked in for replacement under warranty again. I believe they only changed the bushes the last time |
Thu Oct 06 2011 10:32pm |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 |
Their recommendation is valid, but for the wrong reason.
Thu Oct 06 2011 10:43pm |
You can also check the parts catalogue yourself at www.lrparts.ru/engl - takes a bit of hunting for the correct diagram though. For this, look under "chassis". Like this site? Buy some RRSPORT goodies to show your support! |
Thu Oct 06 2011 10:47pm |
Had my NSF lower wishbone replaced for same reason... more cost effective according to dealer RRS gone
Fri Oct 07 2011 1:41pm |
andy r Member Since: 04 Jul 2011 Location: Torbay Posts: 370 |
Polybushes ???? There is a kit for the D3 so should fit & last longer ????
Fri Oct 07 2011 3:00pm |
But the labour cost is still a lot more than entire wishbone assembly replacement? Like this site? Buy some RRSPORT goodies to show your support! |
Fri Oct 07 2011 3:44pm |
Monky Member Since: 29 Sep 2011 Location: London Posts: 37 |
Poly bushes would more than likely last the life time of the car so you wouldn't need to keep changing them down the line, does anyone make them for Sports? I used to be a Powerflex dealer but they don't list them, only Disco and P38. Also checked out Superpro, Andy did you say Discovery bushes are the same fitment?
Sat Oct 08 2011 8:24pm |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
i did the complete lower arms, £130 each to the trade if i remember correctly as mentioned not worth the hassle they need to be cut off in most cases anyway thus running the arm. |
Sun Oct 09 2011 4:30pm |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
there are many replacement lower arms available to manufacture spec, use an indy, and the bill will be alot lower. Keep your old arms and pollybush in your own time and re sell. |
Sun Oct 09 2011 5:20pm |
Gp123 Member Since: 06 Sep 2012 Location: Cheltenham Posts: 6 |
Boat mad - sorry to jump on your thread - but kind of linked...
Thu Dec 22 2016 9:35pm |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 |
All you needs here http://www.advancedfactors.co.uk/range-rov...13-3-c.asp
Fri Dec 23 2016 6:12am |
Jason kenya Member Since: 02 Jan 2016 Location: Nairobi Posts: 15 |
I've just replaced all the front bushes on my 2005 Supercharged, to polybushes.
Fri Dec 23 2016 8:07am |
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 |
Had my front wishbones replaced last year at local indy, just shy of £800 inc. 4 wheel alignment. |
Fri Dec 23 2016 9:53am |
