Home > General (L494) > Putting SIM in MY2017
Page 2 of 4 <1234>
wilf
Where exactly does the SIM card fit into? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #512616 Mon Dec 19 2016 4:35pm
scrumps
On a 17 MY it fits into a slot in the centre cubby
http://www.ownerinfo.landrover.com/documen...c/G1821985
In a 16 MY it fits in the RH side of the dash.
http://www.ownerinfo.landrover.com/documen...c/G1855095
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #512624 Mon Dec 19 2016 6:32pm
wilf
I see, thanks. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #512639 Mon Dec 19 2016 8:58pm
qwick69
Dealer has said that it is my SIM. My EE sim is the multi size one. You have to snap out the surround to reduce the size to the SIM you need. It can go down one smaller. Dealer is saying these do not fit properly, you have to get the SIM that is the correct size. I thought ALL SIMS were now designed like this.
Has anyone else experienced this problem? What SIMs do other people use?
Post #512729 Wed Dec 21 2016 2:29pm
HemoRRS
Seems stupid, sims are a standard size, micro, nano or full sized.
It even says on their site-
Quote:
To fit a micro SIM card, insert the card with the contacts facing up and the shortest end facing out. The card should not be protruding once correctly inserted.
So any micro SD card should fit.
Most providers use these snap out variety now and I've never had a sim not fit a phone.
Post #512730 Wed Dec 21 2016 2:39pm
scrumps
I've know the little "pips" left around the sim when it's snapped out to cause a problem in a SIM carrier.
Judicious use of a craft knife or ladies nail emery board to smooth the edge has cured it.
As the SIM in a 17MY pushes straight in the slot, it could be your issue.
Worth a punt I'd say.
Post #512731 Wed Dec 21 2016 2:50pm
DavidHem
is anyone just using their phone's data for the internet connectivity for the car by the use of the phones Hotspot setting, LR say it can be done.
CONNECTIVITY
Connectivity methods include:
Wi-Fi Hotspot: Creates a Wi-Fi Hotspot in the vehicle, to allow connection of Wi-Fi equipped devices, e.g., tablet, laptop, smartphone, etc., to the internet. Also allows sharing of media between the Wi-Fi equipped devices inside the vehicle.
Wi-Fi: Allows the vehicle to connect to the internet using an external Wi-Fi network.
Mobile Data: Allows the vehicle to connect to the internet via a mobile network, using a data-enabled micro SIM or nano SIM card.
Post #512743 Wed Dec 21 2016 5:46pm
qwick69
Right, I think its sorted.
Despite many attempt be myself and dealer, I could not get the SIM to work. Dealer said faulty SIM, SIM supplier said nothing wrong with SIM. I confirmed this buy putting SIM in my phone and it worked.
So, I sourced an "adapter" that allowed the sim to be used in many appliances. I clicked the SIM out of its current adapter and put it in this stand alone adapter, and hey presto it works.
HOWEVER, the APP on the mobile phone seems to have stopped working when the SIM is fitted in the car, so I cannot put remote heating on, or use the remote lock and "find my car".
Solve one problem, and create another.
Probably some set up menu deep inside the settings somewhere. Why cant cars just have on and off switches now Smile
Anyone else experiencing issues ??
Post #512778 Thu Dec 22 2016 9:46am
Tim in Scotland
First signs of onset of old age/ technophobia ................... you know the answer to all of these problems is to call in a 5 year old child................ they can fix and program anything electronic these days! Laughing 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #512786 Thu Dec 22 2016 10:52am
qwick69
Funny you should say that.
If truth be known, it was my 13 yr old daughter who suggested changing the adaptor Smile
Post #512787 Thu Dec 22 2016 10:55am
Jimbo095
Perhaps a silly question but is it easy to remove the sim seeing as it's such a faff to get it in!?
Post #515393 Sun Jan 22 2017 8:38am
scrumps
I don't have a 17MY but the guidance at the link above says to remove "Gently press in and release"
Very Happy
Post #515467 Sun Jan 22 2017 5:44pm
matsoutback
Australia
I don't have my MY17 yet, and I didn't order it with the " In Control Connect Pro Pack" (all up around $2800.00) but still obviously have the In "Control Touch Pro" 10.2" screen.
I do wonder if I use my phone as a hotspot, would the connected navigation work and the browser work etc..?
I did order the in control apps so I can use my Spotify...
Mat 2017 MY17 SDV6 SE
Post #515529 Mon Jan 23 2017 8:28am
Caerketton
Thank you to the instructions above. The sim is now working in new MY17 AB
Post #516181 Sun Jan 29 2017 11:02am
pko
England 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
Hi Caerketton. What was the final solution?. I've tried three different cards, all on different networks, and although the card is read, & shows the network name, nothing happens for 20 mins then I get the message, "cannot connect check network settings". Any advice would be appreciatted. current 2015 hse dynamic, grey.
Post #520854 Tue Mar 14 2017 12:14pm
Page 2 of 4 <1234>
