![]() | Home > General (L494) > Putting SIM in MY2017 |
pko Member Since: 31 Jul 2011 Location: norfolk Posts: 193 ![]() ![]() ![]() |
Thank Caerketton. It seems a trip back to the dealer is required. The car is recognising the card & identifying the network on each of the three cards I've tried but that's as far as it goes.
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
I got the car to read the SIM OK once I'd worked out which way round to put it (the instructions are designed for that unit when it's fitted horizontally, and therefore read nonsensically when it is fitted vertically as in the MY 17). However, mobile data defaults to 'off' every time I turn the engine off, so you have the faff of going through menus to turn it on again every time. Has anyone found a way to make it stay on? |
Got it sorted, but I had to put u/n & password in manually, the car wouldn't read it from card & when it asked for u/n & p/w I was putting in my account details not the ones required for internet access. |
matsoutback Member Since: 13 Jul 2016 Location: Queensland Posts: 152 ![]() ![]() |
No ![]() |
ianmo Member Since: 08 Jan 2017 Location: Southampton Posts: 119 ![]() ![]() |
I have had my sim (Three 20gb per month) installed from the day I collected it from the dealers without any problems whatsoever, then I get in it this morning and on my way to London notice that I am not getting any traffic updates or email's on my phone and Spotify won't connect.
Silty Member Since: 01 Dec 2016 Location: Aberdeen Posts: 59 ![]() ![]() |
I thought Spotify was run via the Apps on one's phone? I don't have a SIM and I've been holding off getting one as most things I need (i.e. Spotify and web access) are on screen when I connect up my phone. 2017 SDV6 Autobiography; Carpathian Grey, Ivory, Soft Close, Extended Grand Black. |
Mine periodically loses 3G, the reason being that the system turns mobile data off on its own. To get the card recognised again you have to go into the menu ('Communications') and turn it on again, then it all re-boots. Have you tried this? |
When I go into the menu I don't have an option for communications, I go menu features, it then gives me my options, I have conectivity but thats it! |
Spotify is run through the apps, but I have my phone connected to the cars wi-fi so that I don't use masses of data on my phone. |
Thanks donny dog, all sorted now. I will keep an eye on this in future. ![]() |
Great, glad you're sorted (despite me putting 'communications' instead of 'connectivity' - should have gone to the car and checked! |
rstebbings Member Since: 16 Feb 2012 Location: Northallerton Posts: 216 ![]() ![]() |
Don't try putting nano sim in it's a pain to get out, wish I read this before hand. Bit of sticky blue tack helped.
aks Member Since: 13 Jul 2015 Location: Hertfordshire Posts: 21 ![]() ![]() |
Why do LR make this so difficult? I have BMWs and it comes pre-installed and active for the first 3 years!
Huh got in it this morning and it has switched of data again, looks like this will now be an on going problem! ![]() |
