Home > General > 2005 2.7tdv6 rear end knocking
hewiboy
Good Evening Everyone ,
Can anyone give me some advice on this problem i have , i have a annoying knocking from NSR on bumps or grids and its giving me the right hump , ive had rear shocks done along with drop links and sway bar bushes all within the last 5,000 miles . This clunk has only appeared in the last week and ive had it in the air on the ramp all seems solid no play in any bushes etc . Also around the same time it has developed and wining from rear NSR brake when reversing only .... Any tips or suggestions will be greatly welcomed Thumbs Up
Post #512353 Thu Dec 15 2016 7:25pm
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Does it sound suspension related ? or could it be something like one of the exhaust rear boxes moving too much (ie one of the rubber mounts has broken).
I believe that there was a modification to the anti-roll bar bushes to prevent knocking, but I can't remember whether this was just related to the front ones. There's a sticky related to this on here somewhere.
Post #512369 Fri Dec 16 2016 9:58am
also maybe the rear brake caliper is stuck on. A common problem.
After driving, see if the rear wheel is hotter than the fronts/others
Post #512375 Fri Dec 16 2016 12:27pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
There some heavy swinging weights at the back- mine was knocking against one of the exhaust pipes. Local exhaust man applied a bit of heat to the exhaust and moved it out of the way- problem solved
Post #512455 Sat Dec 17 2016 12:10am
Bess06
United Kingdom 2009 Range Rover Sport TDV6 HSE Java Black
Hi I've same problem with my rrs. It's the dsc.take the fuse out ofain fuse box next to battery it's a 15 amp . I tried it and the knocking stopped . Replaced fusee it's back . Has me baffled. Can anyone help
Post #513204 Fri Dec 30 2016 7:11pm
