Home > General > 2005 2.7tdv6 rear end knocking |
hewiboy Member Since: 08 Nov 2016 Location: North West Posts: 9 |
Good Evening Everyone ,
Thu Dec 15 2016 6:25pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5002 |
also maybe the rear brake caliper is stuck on. A common problem.
Fri Dec 16 2016 11:27am |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
There some heavy swinging weights at the back- mine was knocking against one of the exhaust pipes. Local exhaust man applied a bit of heat to the exhaust and moved it out of the way- problem solved |
Fri Dec 16 2016 11:10pm |
Bess06 Member Since: 28 Dec 2016 Location: Carlisle Posts: 3 |
Hi I've same problem with my rrs. It's the dsc.take the fuse out ofain fuse box next to battery it's a 15 amp . I tried it and the knocking stopped . Replaced fusee it's back . Has me baffled. Can anyone help |
Fri Dec 30 2016 6:11pm |
