![]() | Home > For Sale & Wanted > Found!!! Land Rover Winch Sump Guard |
Jobs well done then! IIRC from when member VA fitted one to a TDv6 RRS in the early days there can be problems with the front PDC heads and you may need to re-route or blank them off, also be careful with the sensor for the SRS/Airpbags.
Cheers Tim, still need to source the correct bolt kit for this now as I'm rather fussy about things being right, must be an OCD thing!
Right place right time |
Buckster if you have time search for posts by VA (there will be hundreds so you may need to add a filter like "winch", his RRS is the only one apart from G4's and an LRE car I have seen with a winch. Might be photos in his galleries 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
So after a lot of negotiation with the owner on this brand new and unused Warn 9.5 XP-Synthetic Winch I finally have my paws on it after a 2hr journey each way. He brought it but never fitted it and it has sat in the box since he got it!
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9016 ![]() ![]() ![]() |
Bloody hell Chris! That's as jammy as a jam sandwich dropped in a big vat of jam!
I'm still looking for you mate, I was thinking of lending uncle ray my non winch Sump plate for a measure up |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Might be interested in that too - GB? |
Buckster, any idea what the difference is between the "Synthetic" and "non-Synthetic" winches? I assume it is either the fair lead or the barrel design is different, but it may be that the Synthetic has a helix drive that will run the rope cleanly along the barrel so it doesn't bunch up in one place under load.
Tim,
![]() 2008 TDV8 - it was a labour of love and is much missed |
Toonarmy Member Since: 13 Nov 2016 Location: South shields Posts: 9 ![]() ![]() ![]() |
Very interested in seeing pics of this fitted looks good gear |
As soon as I find the time to fit I will post pics, winch tray and brackets are currently with the powder coating lads next door as were a little scabby in places |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
Watching |
