Home > Technical > Handbrake stuck on and red flashing warning light
Sporticus
2006 Range Rover Sport TDV6 HSE Java Black
Hi all.
After 4 weeks of trouble free ownership and wondering what all the "big bill" warning brigade were all on about I now have my first fault!!
The epb actuator made the horrible screeching noise and failed to disengage on one side. I tried in vain to release it with the emergency pull under the console but as the car was stuck in the garage I had no option but to cut the cable to release the tension.
Im now mobile again but have the red flashing handbrake warning light cosntantly illuminated.
Could this fault be deleted and light stay off as long as I dont pull the switch again?
And how much should I be looking to pay for a new one supplied and fitted?
I could fit it myself but I believe the set up of the system needs a specialist so dont know whether its worth me even getting my hands dirty?
Post #512104 Mon Dec 12 2016 10:01am
Tim in Scotland
If you aren't too far from Dundee then forum member Disco-Mikey is your man, he currently has an RRS he's breaking so you might get a used EPB release wire from him (or a whole unit) and he can set them up too............. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #512111 Mon Dec 12 2016 10:50am
DrRob
^^^ Wot he said. Go to Dundee Thumbs Up Visitor from fullfatrr.com
Post #512121 Mon Dec 12 2016 12:05pm
Sporticus
Been quoted £870 supply and fit for actuator and cables plus £212 if it needs rear shoes
Post #512135 Mon Dec 12 2016 4:03pm
DrRob
Big Cry
If I was in Scotland, I'd take it to Mikey Thumbs Up Visitor from fullfatrr.com
Post #512143 Mon Dec 12 2016 6:32pm
It probably doesn't need a new EPB module. The cables (from module to wheel hub) are replaceable individually and the shoes aren't that expensive. It's entirely possible that the fault is a knackered EPB shoe rather than the EPB module itself. I reckon you should be able to get it done for much less than you're being quoted. 2012 SDV6 - it's missing a couple of cylinders
Post #512161 Mon Dec 12 2016 10:11pm
HemoRRS
If you want to have a go yourself probably everything you need here.
http://www.disco3.co.uk/gallery/thumbnails.php?album=4184
Courtesy of Bodsy
Post #512172 Tue Dec 13 2016 1:28am
flydive
Had the same couple of weeks ago.
Was unable to release it using the emergency pull cable.
Luckily I had the IIDTool with me, cleared the message once but came back, cleared a second time and the message disappeared and the brake released.
I haven't used it since, covered the lever with duck tape on the lever to avoid pulling it by mistake, waiting for the weather to worm up(long wait) so I can the work on it. '08 RRS TDV8
Post #512191 Tue Dec 13 2016 11:58am
Mail Order Ride
Complete and utter mickey take
Is that at a main dealer by any chance??
If not then you need a new indie Smile
Mine failed over the summer at 7 1/2y of age
Indie stripped it down and rebuilt it for a couple of hundred quid
He said he's hardly ever fitted the complete new module and if so hed have charged me less than half of your quote using JLR parts
Post #512227 Tue Dec 13 2016 6:31pm
