Home > Tips & Tricks > Installing Side Steps without taking wheel off?
adamm19830
United Kingdom 2005 Range Rover Sport TDV6 HSE Bonatti Grey
Hi all,
I received a set of side steps today for my RRS 2005 and I've just been to look at the job before I install tomorrow.
There are 2 small screws to take out near to the rear wheel that fixes the existing sill. These are a pain to access as there is minimal room between the screw and wheel.
Any suggestions on getting these screws out without taking the wheel off?
Thanks
Post #511778 Wed Dec 07 2016 10:11pm
B9BS X
These vids should help Thumbs Up
 RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #511781 Wed Dec 07 2016 10:20pm
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hi, please don't laugh on how i did it Rolling with laughter i held a posi bit in a pair of mole grips @90 degrees , then levered a block of wood behind the grips for the pressure off the tyre..... and it worked a treat !! Thumbs Up Hope this makes sense Embarassed 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #511786 Wed Dec 07 2016 11:14pm
adamm19830
Good idea gornal! I'll try that. My only fear is that as the car is 2005 the screws look rusty and may have seized! Sad
Post #511789 Wed Dec 07 2016 11:36pm
Used very similar method when I fitted a pair except used a small ratcheting spanner instead of molegrips, worked a treat. Thumbs Up also replaced screws with stainless steel one's when refitted.
Ceers
Post #511801 Thu Dec 08 2016 12:38am
Gornal Hills
" Good thinking Col" another good tip eh mate Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #511835 Thu Dec 08 2016 2:13pm
Gornal Hills
Hi adamm, give them a good shot of WD 40 mate and they will come out, plenty of leverage of the tyre Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #511836 Thu Dec 08 2016 2:17pm
Boothy
Great tip
Post #523265 Tue Apr 11 2017 10:53am
madtoro
United States
I just did this last weekend, the posi drive bit and mole grips worked fine for me too.
Post #540045 Fri Nov 03 2017 2:28am
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Just
done this and to be honest took the wheels off as it was easier. It also said 20 minutes a side which I think is complete Censored as everything is so fiddly it took me 3.5hrs but I took my time
Post #540050 Fri Nov 03 2017 8:39am
