![]() | Home > Faults & Fixes > Opinion on door locks. |
Sinisa Member Since: 20 Nov 2016 Location: Skopje Posts: 5 ![]() ![]() ![]() |
how did you solve the problem? |
Sgthomer99 Member Since: 17 Nov 2016 Location: Devon Posts: 12 ![]() ![]() ![]() |
Hi, I've got the same issue with one of my rear doors on the same year/spec car as yours. Reading on this forum it appears it might be a faulty door actuator, which can be bought and fitted by someone who knows how. Just search on here and you'll find all about it! |
adamm19830 Member Since: 21 Mar 2015 Location: Nottingham Posts: 45 ![]() ![]() ![]() |
I watched a video earlier on YouTube where someone changed the little white plastic lever within the lock casing as these are also known to fail. They only cost around £5 each. The problem with the vid is that he didn't go into detail about what the actual problem was. He just said it "didn't lock"
Hi thanks for the update, I have'nt actually checked mine out yet to see what the problem exactly is, but will bear this in mind. Please update this thread how you get on! |
Sure. The doors open and close fine it's just the actual locking of them with with the key fob and dash button. What I find strange is that they lock /unlock fine when using the lock button next to the inside door handle. |
This is the vid on YouTube I saw >>> |
