![]() | Home > Technical > Battery Advise 017 or 019? |
The 019 holds more charge than the 017. Useful table here:
Should you need a new one - https://www.tayna.co.uk/EA1000-Exide-Premi...P7488.html "D2BOYS" code for a few ££ off. |
I agree with most of what Lost for Words post, however, AGM batteries are very very good if you do a lot of short trips. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
ISTR other threads saying same as L for W not worth putting an AGM on an older car than 2010 these you can reset the BCM to deal with the AGM
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Can anyone confirm the battery in the ebay link below is the same as the battery from the tanya website
Osprey63 Member Since: 09 Oct 2015 Location: South Wales Posts: 6 ![]() ![]() ![]() |
Hi
It's not a massive difference. Considering the price difference worth a go and should last a few years |
Cheers Andy K.
