Home > Faults & Fixes > Range rover sport 2.7 2008 help see the foto..
Schizz
Italy
3 light on..... :0(
We can help me ?
Schizz
Bologna - Italy[/img]
Post #509036 Mon Oct 31 2016 8:35pm
RobP
Standard limp mode could be any one of a hundred reasons. Need to get it hooked up to proper code reader to find out what is wrong TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #509046 Mon Oct 31 2016 9:51pm
m8ch1n
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Hi Schizz,
More than likely these are linked to the same fault.
Some may disagree, but to me looks like a possible brake fault which would cause the others to come on?? That is assuming the handbrake is off in this pic.
Be aware your DSC will be switched off automatically by the system until this is resolved.
Best bet is to get it scanned
Check simple things like brake fluid level and brake pad wear and wear indicators.
Remember warning lights can come on for a number of different reasons. They are just to point us in the right direction (most of the time) not diagnose the faults. Current: RRS 2010 L320 Facelift 3.0 TD V6 HSE 5dr Alaska White
Gone:Mercedes C220 Estate AMG MY 9/2012 Polar White
Gone:Mitsubishi L200 Raging bull edition MY 9/2009 2.5l DID Red
Gone:BMW 116i MY 4/2006 Silver
Post #509047 Mon Oct 31 2016 9:51pm
Schizz
Italy
Thanks for all !
Today 3 light on in one moment...after l have connect a obd2 tester, and write me "U0416
Invalid Data Received From Vehicle Dynamics Control Module
Stato del DTC
DTC in sospeso
DTC confermato
Test non riuscito dall'ultima cancellazione
Stato del motore al comparire dei guasti
Nessun dato disponibile"
after error reset after some km. Same problem...said also "hdc ? problem and gear problem" but the car work well.
But when write the error suspension non work and other function snow ecc not work.
Is possible the brake low ?
sorry for my English......
Schizz
Post #509051 Mon Oct 31 2016 10:16pm
Schizz
Italy
Please help me.....
Post #510273 Thu Nov 17 2016 8:22pm
PEACHY
Does the suspension compressor work as it should ? try raising & lowering it continually for 5 minutes after the fault is reset. 16MY Estoril Blue SVR.............
Post #510292 Fri Nov 18 2016 7:43am
Schizz
Italy
reading on the forums it seems the problem caused by 'brake switch located under the platform of the driver, then replace tell you ...
Schizz
Post #510293 Fri Nov 18 2016 8:07am
Schizz
Italy
fixed by replacing the brake pedal switch in the driver's side
Post #510750 Fri Nov 25 2016 2:34pm
panda
Thumbs Up Well done Schizz Thumbs Up
Post #510756 Fri Nov 25 2016 3:32pm
