![]() | Home > Faults & Fixes > Range rover sport 2.7 2008 help see the foto.. |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
Standard limp mode could be any one of a hundred reasons. Need to get it hooked up to proper code reader to find out what is wrong TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
m8ch1n Member Since: 26 Oct 2016 Location: Lancashire Posts: 28 ![]() ![]() ![]() |
Hi Schizz,
Schizz Member Since: 03 May 2015 Location: Bologna Posts: 26 ![]() ![]() |
Please help me..... |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Does the suspension compressor work as it should ? try raising & lowering it continually for 5 minutes after the fault is reset. 16MY Estoril Blue SVR.............
reading on the forums it seems the problem caused by 'brake switch located under the platform of the driver, then replace tell you ...
fixed by replacing the brake pedal switch in the driver's side |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
