Home > Faults & Fixes > Possible fix for hdc, normal suspension, transmission fault |
snorky65 Member Since: 26 Sep 2016 Location: plymouth Posts: 3 |
Hi everyone, new to this site but what a great place for help and info.
Tue Sep 27 2016 3:43pm |
Thanks Phil, I did read that the battery can be a major problem on these cars.
Mon Oct 03 2016 10:00am |
Update Still getting suspension faults so dont think the door switch is connected,
Fri Nov 25 2016 9:12am |
You can check the suspension level sensors are all OK by going to the 4x4 Info screen in the central screen. On the screen, above each wheel there should be a white bar like a minus /hyphen sign - if any of them is red then there is a fault with that sensor. Another thing to check is that all the tail lights are working OK, often a lamp failure round the rear can throw up strange fault alarms. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Nov 25 2016 9:40am |
Kenny_Reed Member Since: 11 Jan 2018 Location: California Posts: 3 |
Looking forward to this solution |
Thu Jan 11 2018 8:49pm |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 311 |
Replace the battery, I had all those faults coming up randomly when I bought my 07 tdv8. Bought it a new, good quality AGM battery, no issues since. |
Thu Jan 11 2018 10:52pm |
