![]() | Home > Faults & Fixes > Possible fix for hdc, normal suspension, transmission fault |
snorky65 Member Since: 26 Sep 2016 Location: plymouth Posts: 3 ![]() ![]() ![]() |
Hi everyone, new to this site but what a great place for help and info.
Thanks Phil, I did read that the battery can be a major problem on these cars.
Update Still getting suspension faults so dont think the door switch is connected,
You can check the suspension level sensors are all OK by going to the 4x4 Info screen in the central screen. On the screen, above each wheel there should be a white bar like a minus /hyphen sign - if any of them is red then there is a fault with that sensor. Another thing to check is that all the tail lights are working OK, often a lamp failure round the rear can throw up strange fault alarms. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Kenny_Reed Member Since: 11 Jan 2018 Location: California Posts: 3 ![]() ![]() ![]() |
Looking forward to this solution |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 320 ![]() ![]() ![]() |
Replace the battery, I had all those faults coming up randomly when I bought my 07 tdv8. Bought it a new, good quality AGM battery, no issues since. |
