Home > Faults & Fixes > Supercharged misfire/eml with no codes
Topcat2308
2006 RRS S/C. EML comes on (solid amber) every 150 miles or 3 hours of ignition on. No codes. Reset a number of times same issue at similar miles/ time. Changed plugs, coil packs, checked harness with no issues. Seems to have a slight misfire/unevenness at idle but is not noticeable whilst driving. MPG avg is showing around 18-19 but occasionally seems a little down on power for short intermitted periods which is slight but noticeable then regains normal condition and will be fine again. It is frustrating as I have to drive 120 miles each day and have to wait to see if light reappears after each spanner session and reset. I have a solus pro diagnostics and have looked at various data and all looks well with the exception of a raised long term fuel trim on bank 2. I would expect a code from the O2 sensor but not a dickiebird. I am going to change this at the weekend. Has anyone out there had anything similar or any ideas?
Post #510706 Thu Nov 24 2016 9:33pm
Socast
Have you checked that the injectors are vaporising the fuel correctly ?
That could be the cause of the increased fuel trim and slight stumble etc.
Post #512394 Fri Dec 16 2016 3:08pm
Orange RRS
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
Have you checked the wiring to the charge cooler pump, the factory reversed the pins and the fluid flows the wrong way round the system not cooling the air properly, it's a simple case of reversing the pins in the pump connector. It was a tsb back in the day. Life's too short to drive boring cars !
2005 Supercharged First Edition
2013 Evoque
Post #512411 Fri Dec 16 2016 4:11pm
Socast
The aux pump would throw a reduced performance warning along with massivley restricted performance.
Post #512603 Mon Dec 19 2016 1:52pm
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
I have a 2006 RRS S/C and the EML kept coming on amber after travelling for a couple of Miles.
After trawling through lots of posts on this forum I found a possible cause.
Unlikely as it may seem - a fuel cap not fully tightened. After other things didn't work I decided to give it a go.
A couple of clicks on the cap and a few miles later light out. Very Happy 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
1952 Rover 75 (Cyclops) First Car !!! Fond memories -was restored-good for 93mph.
Post #522389 Thu Mar 30 2017 11:14pm
Eaters
Don't you just love these cars? Rolling with laughter Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #522447 Fri Mar 31 2017 5:07pm
