Home > General (L494) > Leaking rear differential seal
TonyM
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Visit to local dealer after finding lubricant under the rear axle on the garage floor. Second vehicle they have seen with a leaking seal. They don't have the required tool to remove / replace the seal yet. LR also supposed to be looking at the fault and have issued a service note or similar to dealers. Topped up levels but not significant loss. Dealer will keep in touch over coming weeks.
Post #447175 Fri Jan 02 2015 4:42pm
kelvin12382003
I have the same issue. what do i need to do to fix it?
Post #509674 Wed Nov 09 2016 2:21pm
Tim in Scotland
Tony, which MY is your car as I have oil on my drive after the car has been sat for 6 weeks and it is not from my Defender as that has been in secure storage and marking its territory somewhere else! My RRS2 is a March 2015 build and delivery 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #509678 Wed Nov 09 2016 3:16pm
kelvin12382003
mine is a 2013 autobio. i also found some oil leak on my drive!!
Post #509679 Wed Nov 09 2016 3:18pm
TonyM
That RRS2 was on a 63 plate. Dealer checked levels and advised to monitor whilst the tool was obtianed. Since changed to 16 plate model amd no issues.
Minor issue at the time, more bothered about the driveway...
Post #509683 Wed Nov 09 2016 4:04pm
Peanut
Same problem 2015 MY Autobiography.
Diagnosed in February at home by LRA as I did not know how long it had been leaking and whether level was low.
He booked it into dealer and sorted. Took a couple of weeks due (I was told) to heavy workload.
I had a Disco Sport for that time.
LRA man said it was not common........
Poor batch of oil seals? Current: MY15 RRS2 3.0 SDV6 Autobiography Dynamic, Aruba Gold, HUD, Meridian 1700w
Gone: RRS TDV6 2007 Stornaway
Gone: P38 2.5 DHSE
Post #509685 Wed Nov 09 2016 4:30pm
wilf
Had a new diff fitted to mine a short while ago for the exact same issue. MY16. 13k miles
Also got the "no special tool available to facilitate repair" line, which I do find, um, strange.
Whatever, the new diff works fine, and it cured the high speed driveline vibes, too. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #509700 Wed Nov 09 2016 7:45pm
PetesRRS
Australia 2013 Range Rover Sport SDV6 HSE Fuji White
Interesting reading My MY15.5 is booked in next week to have oil leak from rear diff fixed. Told they have to get oil looked at. If it contains bits of metal they replace diff. Car has done 26000 kilometers. 16000 of those towing my off-road caravan.
Post #509721 Thu Nov 10 2016 5:58am
wilf
You must need a step ladder to get in and out of that, lol. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #509730 Thu Nov 10 2016 8:51am
Russben
That's one heck of a caravan Shocked I'm in the shed, I'll be back in the real world in a minute.
Post #509763 Thu Nov 10 2016 3:57pm
PetesRRS
Yeah van is certainly high but great off road. Now just had a call from service guy. Found oil leak in diff but also found a bearing rotates in diff housing therefore new diff required. I have a rear locking diff and none available in Australia. Has to be ordered from U.K. Will take a minimum of 2 weeks to arrive. Guess I will just have to enjoy the new Evoque they provided.
Post #510289 Fri Nov 18 2016 7:07am
IRBails
Australia
I have 26,000 up now and hope they fixed the issue in the 2016 models. seems a very common problem. Like the Van pics also the use of the RRS as a true 4WD vehicle. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #510298 Fri Nov 18 2016 9:40am
mlines
MY16 (Sept 2015) Autobiography Dynamic. In at dealers to fix a brake pedal noise which was diagnosed as Fuel Tank Slosh. When removing the tank they discovered oil leaking from the differential so now having the seals replaced and the differential checked. 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #528279 Fri Jun 16 2017 1:13pm
