Home > General > HELP NEEDED!
Alonso92
United Kingdom 2008 Range Rover Sport TDV6 SE Santorini Black
HELP NEEDED!
Hey guys,
From a long time lurker, I have a 2008 RRS and it is just not opening wit the key fob. Don't know if it would make a difference, but I got a new key fob about 3 months ago (not from land rover) and it was working fine. When this fob stopped working the other day, I used the spare which was only unlocking the drivers door but now neither key is working.
I googled to see if it was the battery even if it is unlikely that both of them will go a day apart and apart from that, I read that the fob battery gets charged whilst driving.
Alternatively does anyone know if there is a way of using the flip out key? Any ideas? All suggestions will be gratefully welcomed Very Happy
Post #508380 Sat Oct 22 2016 11:02pm
B9BS X
If your unable to get into the car without the fob you can remove the cover on the door handle on the passenger side lock then get into the car manually and check if car starts up ok, if it starts up fine then its best to drive to your local indy or stealership for them to dianose and if it dont start up due to a flat battery then give the battery a good charge and key fob should start working again Thumbs Up RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #508381 Sun Oct 23 2016 12:40am
or it has been known that starting the car resets the keys
Post #508388 Sun Oct 23 2016 8:51am
Alonso92
Cheers guys, i have taken the cover off and have been using it with the key...just thought there might be a common fault or an easy way to reset the keys(s) without taking it to a stealer dealer.
Post #510145 Tue Nov 15 2016 9:38pm
