![]() | Home > General > Slight groan |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9029 ![]() ![]() ![]() |
Suspension compressor is in front of the near side rear wheel so opposite side of the vehicle from your noise. 2012 SDV6 - it's missing a couple of cylinders
Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312 ![]() ![]() ![]() |
Thanks sorry I should have known that |
On the TDV8 on the right hand side of the engine (when sat in the driver's seat looking forwards) you have the generator (top) and the dynamic response pump (bottom). The dynamic response valve block is below the driver's door on the side of the chassis rail. There are pressure valves in the dynamic response system but I would have thought a fault would throw up an error on the dash.
Many thanks RRSTDV8. That's definitely the area so I reckon its the dynamic response valve puffing slightly. I guess yours isn't doing it as a comparison? |
Can't say I've heard anything from the DR valve block but my TDV8 makes its own set of noises... |
