![]() | Home > Faults & Fixes > door locking issue |
adamm19830 Member Since: 21 Mar 2015 Location: Nottingham Posts: 45 ![]() ![]() ![]() |
I should add that both doors lock fine when you manually flick the lock from inside its just when you are trying to use the key fob or the interior dash lock button. Its just a pain having to manually lock and unlock the doors.
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 ![]() ![]() ![]() |
Hi sounds like door actuators. very common fault (as I have found). Do a search on here for door actuators/locks. Lots of good write ups on here and the disco site if you want to go the diy route about £90 per lock, £200 for an indy to fit.
Great. Thanks for that. I'll take a look. |
