![]() | Home > Technical > BATTERY WARNING LIGHT |
TonyO1 Member Since: 13 Nov 2016 Location: UK Posts: 3 ![]() ![]() |
Hi all, I had a similar detail with the battery. Light came on, got new Alternator (Lucas) from Europart. Got it fitted, it didn't work with old battery, new battery installed, now car has gone haywire! Well the suspension has dropped to bump stops, compressor overheating, I think the new battery may be boiling too as it had a strange smell when I left it. Clearly (in my opinion) there is too much current coming from the new alternator? Has anyone seen this before? Is the fix a new alternator to battery cable? The reason I say that is because there is too much current being drawn and the only thing I can think of is a rusty/poor connection, creating extra resistance but requiring more current due to this? I didn't fit the bits as it seemed like a lot of work to attempt at your front door without the correct gear. I'm fearful of getting it to the LR dealer as they would probably change batt and alternator and hit me with an �800 bill!
tonycash27 Member Since: 25 Aug 2013 Location: Sevenoaks Posts: 26 ![]() ![]() ![]() |
Hi Tony
Hi Tony,
Thats Good Tony
It's a 57 plate with 128k on her. Stills purrs like a kitten. I expect the Denso Alternator that came off was the original, this new Lucas one must have an issue with the voltage regulator |
