![]() | Home > Technical > BATTERY WARNING LIGHT |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
The only thing I can think of is to double check the battery connectors are pushed all the way down on to the battery terminals, and they are on very tight. |
What were the symptoms for having a new battery?
tonycash27 Member Since: 25 Aug 2013 Location: Sevenoaks Posts: 26 ![]() ![]() ![]() |
Symptoms were the usual mix of - special programs off, suspension fault car lowering, suspension fault maximum speed 30mph , park brake fault, suspension lights coming on and off , entering limp home mode, and a few more, new battery seems to have solved this, in for a new alternator today so I will post a bit later with results, in for a service next week LR Dealers and then Indie for a new Turbo.
Fitted New Alternator - Pig to fit 6 hours - cured problem thank god !!!! |
6 hours to fit an alternator to a TDV6? |
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
For a just few quid you can buy a digital voltmeter that plugs in the cigar lighter socket.
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Agree 100%, I have been using one of those plug in digital voltmeters in my cars for years.
mike_D_3781 Member Since: 09 May 2013 Location: west Yorks Posts: 98 ![]() ![]() |
Tony,
gizzmo Member Since: 16 Mar 2014 Location: london Posts: 10 ![]() ![]() |
change the alternator. 100% |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 ![]() ![]() ![]() |
@Tonycash27 and Disco_Mikey..
An alternator on a non-ARC is under an hour
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
I changed my alternator in a little over an hour, (maybe an hour and a quarter) never having done one before. Also, I did not have the tools to remove the viscous fan clutch, so had to improvise. I will definitely get the right tools before I tackle the cam belt. It is well worth getting them.
Raecropwalker Member Since: 04 Apr 2013 Location: East Sussex Posts: 7 ![]() ![]() ![]() |
Hello there. This is the first time that I have asked a question, but have followed the site with interest
Britpart |
