Home > Technical > Alarm goes off - 8 flashes on deactivation
Ian.H
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
Hi all..
Does anyone know the flash codes for the alarm once it's gone off? Mine triggers randomly when set and upon disarming, the hazards flash 8 times in quick succession, but not sure what this code means has been triggered.
I _suspect_ my bonnet pin is at fault, as now and again I get the "bonet open" message appear on the dash for no reason (I've had it out, cleaned it up, I don't get the issue as often but it needs replacing anyway) but confirmation would be good if someone knows for sure?
Any help greatly appreciated Smile
Cheers..
Ian
Post #510011 Mon Nov 14 2016 8:19am
Bodsy
Site Sponsor
It's just to tell you the alarm has been activated. It's not a code for how it was activated. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #510013 Mon Nov 14 2016 9:03am
HemoRRS
Yes it'll be your bonnet switch, to test unplug it and bridge the connection, paper clip works well.
Try that for a few days, if no alarm it defiantly the the switch, only about £20 so one of the better faults!
Post #510014 Mon Nov 14 2016 9:07am
Ian.H
Thanks Bodsy.. I assumed 8 flashes would be bonnet for example, 1 might be interior sensor.. etc etc etc.. thanks for the confirmation.. probably explains why I couldn't find a list of flashes related to trigger cause Smile
Thanks Hemo... I'm planning on heading to Lookers in Park Royal on Friday as I'm off and it's only a few miles down the road to get a replacement switch anyway.. but I'll try bridging it in the mean time as it woke my better half up at 04:40 this morning (no idea how anyone hears the pathetic excuse for a "siren" but somehow it did) and then I must have woke the anyone that didn't hear it by re-arming it and the horn sounding to let you know something isn't closed Evil or Very Mad Rolling Eyes
Cheers..
Ian
Post #510022 Mon Nov 14 2016 10:21am
