Home > General (L494) > Lowering ride height on V8 SC Dynamic?
Compulsive
My first post here!
I would like to lower the ride height on my 2014 V8 SC Dynamic a little bit, probably to approx the level of the the SVR model, so perhaps -20mm max. Note that I DON'T want to make it a bouncy low-rider!
I have seen lowering links but the JLR warranty people would likely throw a fit and I wonder what adjusting the height via links does to the ride quality?? The other option might be to use the GAP IIDTool BT since they claim:
Advanced Programming Functions
Car Configuration / Personalization (CCF editing, full CCF access upon request)
Height Adjustment (front, rear or all)
Suspension individual sensor calibration (needed after a repair)
Backup of original height and CCF values
3 personalized height profiles
Any feedback on lowering and/or the IIDTool BT would be appreciated.
Post #509970 Sun Nov 13 2016 3:23pm
Johnski
Welcome to the Forum.
I use my GAP Diagnostic IID BT Tool for altering heights for my vehicle, ensure you record original figures before you start.
I see no reason this would stop any warranty, hasn't on my car, unless you go mad and it stands out, if you go to low with adjustments it can bottom out.
Read the various threads on this, if having a service at a LR dealership, I'm sure they would do this while in for service, at a not to expensive cost. John
Post #509975 Sun Nov 13 2016 4:11pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
Re: Lowering ride height on V8 SC Dynamic?
Compulsive wrote:
My first post here!
SVR ride height is the same isn't it?
Post #509985 Sun Nov 13 2016 7:16pm
Compulsive
The SVRs certainly appear to sit lower, whether they are sitting on the 21" or optional 22" wheels, compared to my V8 SC Dynamic model. I am not confusing the parked/loading height with standard operation height Razz
Regardless, I would like my RRS to sit approx 15mm to 20mm lower than it sits now.
Post #510006 Mon Nov 14 2016 1:35am
DaveW
Phil is correct; SVRs run exactly the same ride height as the standard cars. That's the whole point of them being as effective off road as their standard partners.
Lowering your car by 15-20mm permanently will lead to all manner of suspension system durability issues in the long term and more importantly, turn what is a nicely handling SUV into something completely different.
It's up to you if you do it, but just be aware of warranty implications etc
Post #510009 Mon Nov 14 2016 8:13am
Tyrefitter
Also lowering it will alter geometry & it could start scrubbing tyres off unless you have it aligned when its been lowered.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #510012 Mon Nov 14 2016 8:50am
DaveW
Hence my comment on durability as it may not pull back in on Geo from that far
Post #510018 Mon Nov 14 2016 10:04am
