Home > Maintenance & Modifications > Engine Fault
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Engine Fault
Hi Lads
Sorry for repeating this question, Over the last couple of weeks I have had the loss of power symptom when pushing the Sport mostly when going uphill.
Same as before the Engine loses power and seems to go into limp mode , "Special Programs Off " warning comes up on dash.Then I stop car switch off and re-start and all is okay again.
Would really like to try and get to the bottom of this fault ,so any help / suggestions on how to cure this would be much appreciated guys
Thanks John Confused Thumbs Up
Post #508592 Tue Oct 25 2016 8:36pm
Disco_Mikey
Split turbo hose/Intercooler
Seized turbo actuator
Blocked/faulty fuel filter
Low pressure from in tank pump
HPFP fault
Could be many things Big Cry
Post #508595 Tue Oct 25 2016 9:02pm
Macca
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Had similar problems no dash warnings. Check Turbo actuator not sticking D3 TDV6 SE auto 2006
FFRR TD6 vogue SE Overfinch 2006
RRS TDV6 HSE 2007
L322 4.4 TDV8 Overfinch 2012
Post #508611 Wed Oct 26 2016 7:15am
DrRob
Take it to Dundee and let DM sort it Thumbs Up Visitor from fullfatrr.com
Post #508642 Wed Oct 26 2016 11:23am
Jock 77
Re Engine Fault
Hi Lads
Thanks very much for the replies ,I have a few days off next week so will firstly try and check the Turbo Actuator and the Turbo to Intercooler hose. I have always used Delphi Fuel filters and last change was only a few months ago but have had the problem intermittently before the last change.
The problem only seems to happen when it's pushed hard Uphill ,if the throttle is eased smoothly it all seems to work okay.
Will try and have a look at earlier posts to see the best way to check these, Am I right in saying the Actuator can be accessed from the passengers side wheel arch. And is it better to remove the Turbo to Intercooler hose to check.
Will try these two checks next week thanks guys. If not these will probably organise to bring it up to you Mikey if that's okay bud to check fuel pressure's Thumbs Up
Cheers again Jock Bow down
Post #508691 Wed Oct 26 2016 7:42pm
Jock 77
Re. Engine Fault
Hi Lads
Had a look at the Turbo Actuator and hoses last week. The actuator seemed pretty free but gave it a spray with WD40 and worked it a few times when I was in there anyway.
Had a look at the hoses and the short hose had a bit of oily residue around it, so went round all the jubilee clips and managed to get them a bit tighter.
Tried it out and tried pushing it on as much as possible and all seems to be okay at present so fingers crossed. Now considered if it was worth replacing all the hose around the Turbo ,but looks a nightmare to do. Confused
Post #509878 Sat Nov 12 2016 1:26am
Disco_Mikey
They are a fiddly Censored of a job Big Cry
Post #509885 Sat Nov 12 2016 8:20am
Jock 77
Re:Engine Fault
Hi Mikey
Yeah they certainly look a pita to do Big Cry ,Will run it a bit and see how things go .Fingers crossed.
Cheers Jock Thumbs Up
Post #509931 Sat Nov 12 2016 9:31pm
