Home > Maintenance & Modifications > Headlight Lens
Charliecloud
Headlight Lens
Looked at a RRS today and the headlight lens on both headlights looked very 'dull' and not as clear as I would have expected. Is this a normal issue with RRS headlights and can they be buffed up? I assume they are a polycarbonate construction?
Thanks
Post #509050 Mon Oct 31 2016 10:03pm
adameverett
Meguiars do a kit in Halfords for £30, not tried it mind. I touched up my headlights at the weekend they were suffering some discolouration on the tops that was really bugging me.
I had some G4 laying around and a can of clear coat, so set about rubbing them down and laying a clear coat over. Only spent 10mins on each light so not perfect but lots better until getting around to doing something better in the spring.
Lots of vids on you tube.
Post #509063 Tue Nov 01 2016 7:35am
You can rub then down and lacquer them.
You can also get lacquer runs Confused
Post #509083 Tue Nov 01 2016 12:16pm
Charliecloud
Thanks for the info, just looked up the vids, all looks very straight forward
Post #509091 Tue Nov 01 2016 2:27pm
Johnski
Lights can also suffer from condensation, (described in handbook) and although it does clear,
if frequently happening does seem to discolour, leave marks on inside of lamp, which unfortunately you can't clean,
But shouldn't be happening on recent models. Whistle John
Post #509123 Tue Nov 01 2016 10:44pm
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
I used toothpaste to polish out the discolouration on my headlamps, worked very well Thumbs Up
Post #509238 Thu Nov 03 2016 2:33pm
chi
Hi Phillh
Sounds a good idea to clean. Will give it a go as my 2005 lenses are a bit opaque along the top edge.
Did you need to lacquer afterwards ?
Regards
Keith
CHI
Post #509326 Fri Nov 04 2016 3:22pm
phillh
Chi,
No just waxed them for now, will monitor how things go.
Phillh
Post #509342 Fri Nov 04 2016 6:53pm
chi
Hi again Phillh
Ok , thanks for info.
Looks really good:)
Keith
CHI
Post #509523 Mon Nov 07 2016 4:19pm
