Home > Technical > INteresting door lock issue 2012 RRS |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
It does sound like a lock solenoid/sensor/actuator is at fault & these are known to fail. I don't know exactly how to change it, when my rear door lock went faulty it was replaced under warranty.
Tue Nov 01 2016 11:21am |
ozzievechi Member Since: 14 Mar 2016 Location: london Posts: 55 |
same issue, its the actuator....have to reach in and lock it from the inside, or leave window open, reach in and press the lock, then hold lock on the fob and the car locks and the windows roll up
Tue Nov 01 2016 12:41pm |
To the OP: it does sound d like latch failure although when same happened to my car there was no horn sound on locking and it doesn't have auto mirror retract.
Tue Nov 01 2016 1:16pm |
bubblebobble Member Since: 17 Mar 2010 Location: staffordshire Posts: 6 |
Some great replies guys,
Tue Nov 01 2016 4:28pm |
let me know how u get on as I could do without a £200 bill, if itsa case of giving it a clean more than happy to get the feather duster out |
Tue Nov 01 2016 4:33pm |
Don't start until you have read through this thread and the others linked within it as it will save you a lot of time http://www.disco3.co.uk/forum/topic110280....Door+latch 2008 MY Java Black TDV8 HSE |
Tue Nov 01 2016 5:11pm |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
I replaced mine earlier in the year, done it in about 40 mins with the help of wha i found on here.
Thu Nov 03 2016 7:39am |
So we are saying not to lower the window the ,5ish inches or so ? |
Thu Nov 03 2016 8:31am |
I taped up the window to keep it in the fully closed position when I did my driver's side. It seems there is more than one way of doing the job though. 2008 MY Java Black TDV8 HSE
Thu Nov 03 2016 4:21pm |
Hi Chaps,
Sat Nov 12 2016 3:36pm |
