Home > General > Cancel Command Shift Paddles? |
Mine is a later L494 and there is an option in the dash menus to disable the paddles, but rather than disable them if you pull one for a fixed time (IIRC 5 secs) it should return the car to full auto mode. My 2011 and 2014MY Evoques both had that feature to return to full auto mode and to inhibit the paddles too so have a look in your owner's manual 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Oct 23 2016 5:18pm |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
I've checked the manual but will have another look. It was a MY14 XF so maybe not on my MY13 RRS.
Sun Oct 23 2016 6:01pm |
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 |
Dennis,
Mon Oct 24 2016 11:06am |
I read the online manual in Topix and no mention of disabling the paddles, just a reference to when in D it will automatically revert back to auto after a time with no paddle functions, and no acceleration/deceleration. When in S mode it will not revert back to auto unless pulling the upchange paddle for 2 seconds.
Mon Oct 24 2016 3:18pm |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
Pretty sure there wasn't an option in L320 to disable the paddles despite the same engine and gearbox as L494. I find I use the paddles much less in MY16 than I did in MY13 because it is so much more responsive already. However, even though I can disable them or have avaialble only in S in L494, I still keep mine on in both D and S for occassional use. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Mon Oct 24 2016 3:28pm |
Slight off topic direction... but why would anybody actually use those paddles, or even S for that matter? I've driven automatics for about 15 years and the only time I ever use anything other than D is when on steep downhills (Berriedale Brae's etc.) with a trailer/caravan, and then I might drop down from D to 3 or 2 to assist the brakes from heating too much (in my P38, I've only once driven there with the RRS and didn't use them).
Mon Oct 24 2016 3:42pm |
Are you sure about that? Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond |
Mon Oct 24 2016 4:19pm |
m8ch1n Member Since: 26 Oct 2016 Location: Lancashire Posts: 28 |
I've done the same myself, very easily knocked without knowing. I haven't seen a disable option either. The quickest way to resolve this is simply just flick the main gear selector from drive to sport and straight back to drive again. This will cancel out the paddle selector and leave you back in drive. |
Thu Oct 27 2016 2:39am |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
Dropping down a gear or two using paddle shift is handy when preparing for an overtake (from behind a tractor for example) and when descending steep'ish hills.
Thu Oct 27 2016 11:18am |
Also very useful off-road to keep the car in a lower gear than the gearbox ECU might want to be in so you can utilise the engine braking better instead of brakes/ HDC (we don't all use the TR functions off road, some prefer to do it without electrinics intervening). I rarely use the paddles on road but they are still useful even in L494 with the extra power and torque, when overtaking or if as stated above you want to play at manual changes when you want them. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Oct 27 2016 3:59pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1167 |
During the test drive of my soon-tp-be 2015 SCV8 earlier today, I tried the paddles in D, and nothing happened. I had to put it in S mode for the paddles to be active.
Thu May 24 2018 6:55pm |
If you go into the dash menu for the settings there is a menu for the paddles and how you would like to use them 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu May 24 2018 6:58pm |
^^^^ as Tim says,,go into the menu as you can enable them to work either in just sport mode or sport & drive.
Thu May 24 2018 7:19pm |
Ah, thanks for the info.
Thu May 24 2018 7:20pm |
