Home > Technical > Belt Question?? |
Sit Member Since: 14 Jun 2015 Location: Bristol Posts: 208 |
Morning,
Sun Oct 23 2016 9:57am |
Rich Member Since: 14 Nov 2014 Location: West Sussex Posts: 39 |
It's 7. Mine is due and I'm saving up! |
Sun Oct 23 2016 10:46am |
Oh ok that makes sense, thank you for the info. So on an '05 it would be 2012 and then 2019?
Sun Oct 23 2016 11:28am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
It's a brave (and wealthy) man who waits 7 years for a belt change. Broken belt = broken Bank account In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sun Oct 23 2016 12:03pm |
Should add, it's a tad cheaper to replace the Belts on a 2.7 than it is on a 3.0. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sun Oct 23 2016 12:05pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
7yr/105k miles for the 2.7
Sun Oct 23 2016 12:52pm |
Thanks for the info, of course I realise these schedules are 'suggested' but as with most things people have them done earlier so will bear that in mind. I guessing both belts are going to be circa £700 for change at an Indy?
Sun Oct 23 2016 12:58pm |
Why not have a weekend break in Scotland, see if DM can do you a belt chane and a gearbox flush. Mind you, make sure you take an umbrella In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sun Oct 23 2016 2:21pm |
As a matter of interest Mikey, how much for a 3.0 belt change In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sun Oct 23 2016 2:23pm |
3.0 belts are £750 inc VAT, for all 3 belts, idlers, tensioners etc
Sun Oct 23 2016 3:08pm |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 |
I had mine done at Stafford Land Rover for £669, cheaper than any Indy I found.
Sun Oct 23 2016 5:55pm |
