![]() | Home > Faults & Fixes > Drivers mirror moving on its own! |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
I had the same issue when I first bought my RRS, turned out I just had to set the mirror to my preferred position then save it on the seat memory button and never had the problem again |
Macca Member Since: 03 Oct 2016 Location: Nottinghamshire Posts: 17 ![]() ![]() ![]() |
as above - try saving the position on the seat memory |
Thehos Member Since: 24 Jul 2016 Location: Somerset Posts: 123 ![]() ![]() |
Thanks guys, will try that |
Kizza123 Member Since: 25 Aug 2016 Location: Lincoln Posts: 53 ![]() ![]() ![]() |
Nightmare |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 ![]() ![]() ![]() |
I know this is vague but if you have the IIDTool then try disabling the reverse dip function as well as the memory seat setting. Then turn on the car run for 30 seconds and turn off. Then re-enable the features you disabled and start the car. This is what I would do as a way of resetting those functions. I am not saying it will work but if you have the IIDTool then it doesn't hurt to try it.
