Home > Faults & Fixes > Drivers mirror moving on its own!
Thehos
Am not missing something?
When it happens I don't know, but my drivers mirror seems to be in random positions when I jump in it after!
Post #507669 Wed Oct 12 2016 6:55pm
B9BS X
I had the same issue when I first bought my RRS, turned out I just had to set the mirror to my preferred position then save it on the seat memory button and never had the problem again Thumbs Up RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #507675 Wed Oct 12 2016 7:18pm
Macca
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
as above - try saving the position on the seat memory Thumbs Up D3 TDV6 SE auto 2006
FFRR TD6 vogue SE Overfinch 2006
RRS TDV6 HSE 2007
L322 4.4 TDV8 Overfinch 2012
Post #507680 Wed Oct 12 2016 7:26pm
Thehos
Thanks guys, will try that
Post #507702 Thu Oct 13 2016 6:44am
Kizza123
Nightmare
Post #507820 Fri Oct 14 2016 1:47pm
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
I know this is vague but if you have the IIDTool then try disabling the reverse dip function as well as the memory seat setting. Then turn on the car run for 30 seconds and turn off. Then re-enable the features you disabled and start the car. This is what I would do as a way of resetting those functions. I am not saying it will work but if you have the IIDTool then it doesn't hurt to try it.
Good luck
Post #508736 Thu Oct 27 2016 7:22am
