Home > Maintenance & Modifications > Brake pads worn - no way!
Louiscypher
2009 Range Rover Sport TDV6 HSE Bourneville
Hi, after accelerating rather more progressively than normal, the dash lit up with 'Brake Pads worn' yet I had them all replaced probably less than 2000 miles ago. Is there a sensor I can check, I'm assuming there's probably one on each wheel and one's managed to come loose or dislodged? '10 RRS 5.0 SC
'13 Cayman S
Post #507291 Fri Oct 07 2016 5:30pm
Paddi
Hi, on the 2005 - 2009 models there are two brake pad wear sensors: one on the left front and one on the right rear. Most likely one of the leads has corroded or chafed through. They are a bit of a pain to access as you have to remove or at least partially remove the wheelarch liners to get at the plug where they join the loom. Luckily they don't cost too much. 2008 MY Java Black TDV8 HSE
Post #507294 Fri Oct 07 2016 5:40pm
Louiscypher
Hi, many thx for the quick reply, it's a '10 so not sure if it's the same process? Just seems odd to have happened under hard acceleration, made me think somethings come loose? '10 RRS 5.0 SC
'13 Cayman S
Post #507296 Fri Oct 07 2016 5:44pm
KennyR
Scotland
I replaced the rear one on mine a couple of weeks ago, 2000 miles after the pads and disks were replaced, must have came loose and sheared off. It's a bit of a pain to get to the connector but is do able, I didn't have to remove any liner, good news is the replacement was only £4 on fleabay Thumbs Up ____________________
Current: MY2023 3.0 SDV6 Autobiography in Eiger Grey
Gone: MY2019 3.0 SDV6 Autobiography in Carpathian Grey
Gone: MY2015 4.4 SDV8 Autobiography in Corris Grey with ebony and lunar leather
Gone: MY2013 3.0 SDV6 HSE Black Edition in Orkney Grey, piano trim, black leather with contrast stitch
Post #507302 Fri Oct 07 2016 8:20pm
Louiscypher
@KennyR, do you have the fleabay details (to show the part number) and I can probably back-track from there? Cheers. '10 RRS 5.0 SC
'13 Cayman S
Post #507304 Fri Oct 07 2016 10:15pm
KennyR
Scotland
There you go
https://www.ebay.co.uk/itm/171483403835 ____________________
Post #507306 Fri Oct 07 2016 10:37pm
Louiscypher
you sir, are nothing short of a gentleman Smile '10 RRS 5.0 SC
'13 Cayman S
Post #507309 Fri Oct 07 2016 11:22pm
