Home > Maintenance & Modifications > Brake pads worn - no way! |
Louiscypher Member Since: 29 Sep 2012 Location: Northampton Posts: 42 |
Hi, after accelerating rather more progressively than normal, the dash lit up with 'Brake Pads worn' yet I had them all replaced probably less than 2000 miles ago. Is there a sensor I can check, I'm assuming there's probably one on each wheel and one's managed to come loose or dislodged? '10 RRS 5.0 SC
Fri Oct 07 2016 5:30pm |
Hi, many thx for the quick reply, it's a '10 so not sure if it's the same process? Just seems odd to have happened under hard acceleration, made me think somethings come loose? '10 RRS 5.0 SC
Fri Oct 07 2016 5:44pm |
KennyR Member Since: 28 Jul 2015 Location: Gourock Posts: 178 |
I replaced the rear one on mine a couple of weeks ago, 2000 miles after the pads and disks were replaced, must have came loose and sheared off. It's a bit of a pain to get to the connector but is do able, I didn't have to remove any liner, good news is the replacement was only £4 on fleabay ____________________
Fri Oct 07 2016 8:20pm |
@KennyR, do you have the fleabay details (to show the part number) and I can probably back-track from there? Cheers. '10 RRS 5.0 SC
Fri Oct 07 2016 10:15pm |
There you go
Fri Oct 07 2016 10:37pm |
you sir, are nothing short of a gentleman '10 RRS 5.0 SC
Fri Oct 07 2016 11:22pm |
