Home > Faults & Fixes > Gearbox not changing up
Paulg
United Kingdom 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Had issue where gearbox was not changing UP gears when in drive, it would change manual and then when I got up to 3,4,5 or 6 and put it into drive it will allow me to kick down.
No other issues with gear box super smooth and no noise, car has only done 60K.
I parked up and left and it seems to have reset its self for the time being up has anyone going any ideas what it could be?
Post #505898 Tue Sep 20 2016 7:04am
HemoRRS
Are all tyres matching?
See here
http://www.rrsport.co.uk/forum/topic35871.html
Post #505900 Tue Sep 20 2016 8:19am
Paulg
Thank you for the reply.
Yes it has a matching set of pirelli scorpions all with correct pressure one of my first thoughts.
Post #505903 Tue Sep 20 2016 8:49am
Paddi
There was at least one case where an owner complained about gearbox not changing up and it turned out to be an incorrectly fitted stop/tail bulb. That may sound weird but the brakelight circuit is on the CAN and so can interfere with it if there is a fault.
The brake pedal switch can cause odd faults too. It is a simple and inexpensive DIY job. 2008 MY Java Black TDV8 HSE
Post #505915 Tue Sep 20 2016 11:19am
Paulg
Spot on with the brake light bulbs it was that, cannot believe that was the problem.
Thank you
Post #506265 Sat Sep 24 2016 4:43pm
Paddi
Give me a wave when I'm in Hornchurch visiting my mother 2008 MY Java Black TDV8 HSE
Post #506274 Sat Sep 24 2016 5:52pm
