![]() | Home > Maintenance & Modifications > AFS OR NON-AFS? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5067 ![]() ![]() ![]() |
If I can read the number correctly XBC501763 is R/H RHD Adaptive Headlamp Bi Xenon with Cornering Lamp according to parts list, although the number has been superceded.
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Hi Col
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
B9BS X,
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
I reckon they are non AFS lights.
That Part Number Cross References to a new number LR012440 which is the same number as the R/H Light fitted to my Old 09 plate pre-facelift and that had AFS.
xenon's have one unit on the base.
Thanks all, I dont thnk mines are AFS and after reading some old threads sounds like even if fitting AFS lights on my car the chances of them working are very slim |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
I thought AFS was one of the standard features on SC models.. |
Brandonh1998 Member Since: 07 Dec 2016 Location: Cambridge Posts: 31 ![]() ![]() ![]() |
If I buy AFS headlights for my 2010 HSE what else is required for them to function as they do not currently have adaptive feature |
The ECU needs telling that thy're connected. |
You will also need a steering angle sensor as they also have little spot lights - cornering lights - that come on when you are doing less than 30mph and either turn the steering wheel or indicate left or right. They are very useful on dark twisty country lanes and in dark multi storey car parks. This is also how the OP can tell if he has adaptive headlights as you also have the active cornering lights as well with adaptive headlights. I'm not sure if Adaptive were standard on the S/C and as I am about 3000 miles from my collection of brouchures I cannot tell you if they were or not - for sure the 1st Editions had them. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
All RRS have the steering angle sensor, it feeds the info onto the 4x4 info screen (amongst other things). |
So what do I need to buy nothing just get it reprogrammed to the ecu |
I thought it was:
