Home > Faults & Fixes > Limp mode
Matthewdolan
United Kingdom 2009 Range Rover Sport TDV6 SE Stornoway Grey
Limp mode
Can anyone help, my RRS keeps going into limp more, there is little consistency as to when this happens but it seems to have started around the same time as the passenger door lock started playing up)
Post #505735 Sun Sep 18 2016 8:12am
Mail Order Ride
You really need to know the fault codes
I had a fault reader for our old mini which was pretty cheap and I know several threads on here suggest people have them for the RR Sport
Good luck!
Post #505852 Mon Sep 19 2016 4:18pm
Paddi
We could all speculate about the cause of your limp mode but as already said the best way is to connect a fault code reader to the OBD port. Generic code readers have their uses - but really only on run-of-the-mill hatchbacks.
For a complex vehicle like the RRS you need a Land Rover specific tool like the Gap Diagnostics IID but at close to £400 you may find it more cost effective to visit a good Land Rover specialist.
Common causes of limp mode include partially seized turbo variable vanes (or the actuator rod ) and partially blocked fuel filter but there are many other causes.
Problems with the door lock latch motors are very common but usually not connected with limp mode. You can replace the whole latch at parts cost £100 or just the motor at about £10 from fleabay. 2008 MY Java Black TDV8 HSE
Post #505854 Mon Sep 19 2016 5:13pm
DrRob
Try
www.rrlondon.co.uk
www.rovertune.co.uk
Thumbs Up Visitor from fullfatrr.com
Post #505861 Mon Sep 19 2016 7:04pm
