![]() | Home > Technical > incorrect diesel exhaust fluid quality detected |
bfp Member Since: 12 Sep 2016 Location: Surrey Posts: 3 ![]() ![]() |
Has anyone else come across this, 2nd 2016 vehicle with the same issue? |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
What are the symptoms? |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
It sounds like the adblue needs topping up. The car has selective catalytic reduction to reduce NOx emissions and this depends on adblue to provide ammonia for the catalyst. |
If only as simple, quality not quantity. I'm told it's not just me but doesn't seem to be a definite fix at this moment |
Adblue can crystallise, which may be causing your problems.
33Lurcher Member Since: 11 Sep 2023 Location: Glossop Posts: 23 ![]() ![]() |
Any recent update on this as I have just got same message today 2016 model 49000 mls , ad blue filled at independent when supplied and serviced 1500 mls ago . 2016 RRS HSE Firenze Red |
Just rang dealer and booked in for Tuesday to look at . 2016 RRS HSE Firenze Red |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 546 ![]() ![]() |
Thanks for reply , did a bit of searching and found a couple of references to software upgrades of 2016 models .
Sorted at supplying independent today , as far as I can gather AdBlue tank drained and then fluid added in increments whilst software approving each step till fault cleared . 2016 RRS HSE Firenze Red |
