Home > Technical > incorrect diesel exhaust fluid quality detected
bfp
Has anyone else come across this, 2nd 2016 vehicle with the same issue?
Post #505160 Mon Sep 12 2016 1:12pm
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
What are the symptoms?
Post #505196 Mon Sep 12 2016 6:36pm
bfp
No symptoms other than the warning message followed by a second message "car won't restart after xxx miles" car back in with Jlr so I'll update blog when I know more. Bfp
Post #505214 Mon Sep 12 2016 8:38pm
Black Bess
It sounds like the adblue needs topping up. The car has selective catalytic reduction to reduce NOx emissions and this depends on adblue to provide ammonia for the catalyst. Thumbs Up
Post #505599 Fri Sep 16 2016 12:33pm
bfp
If only as simple, quality not quantity. I'm told it's not just me but doesn't seem to be a definite fix at this moment
Post #505616 Fri Sep 16 2016 3:23pm
Black Bess
Adblue can crystallise, which may be causing your problems.
Will be interested to hear the outcome.
Post #505617 Fri Sep 16 2016 3:25pm
33Lurcher
Any recent update on this as I have just got same message today 2016 model 49000 mls , ad blue filled at independent when supplied and serviced 1500 mls ago . 2016 RRS HSE Firenze Red
Post #637373 Fri Nov 17 2023 1:14pm
33Lurcher
Just rang dealer and booked in for Tuesday to look at . 2016 RRS HSE Firenze Red
Post #637374 Fri Nov 17 2023 1:28pm
scrumps
Ad blue quality can vary, just like engine oil quality.
The manual for my 24MY states:-
Diesel Exhaust Fluid (DEF). Diesel. AdBlue™ meeting ISO 22241 and ISO 22241-1.Diesel Exhaust Fluid is also known as DEF, AdBlue, AUS 32 and ARLA 32.
I have heard of some types of Ad Blue being “over diluted” and I seem to recall there was a software update on my 16MY L494 about “ Ad Blue quality”.
I always buy a reputable brand ( Redex).
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #637382 Fri Nov 17 2023 5:38pm
33Lurcher
Thanks for reply , did a bit of searching and found a couple of references to software upgrades of 2016 models .
Hopefully dealer will sort on Tuesday . 2016 RRS HSE Firenze Red
Post #637385 Fri Nov 17 2023 6:39pm
33Lurcher
Sorted at supplying independent today , as far as I can gather AdBlue tank drained and then fluid added in increments whilst software approving each step till fault cleared . 2016 RRS HSE Firenze Red
Post #637497 Tue Nov 21 2023 7:08pm
