Home > Maintenance & Modifications > Front window washers |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4941 |
It's certainly interesting that the rear one still works. It uses the same pump and filter,. IIRC
Tue Sep 13 2016 5:11pm |
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 |
Yes def pump running when push button on stalk, I even took headlight out and got someone to push washer button and can hear pump running, I also disconnected pipe from passenger side jet and blew hard down pipe and clearly heard washer fluid bubbling away in washer bottle so pipes seem to be clear and connected,
Tue Sep 13 2016 5:56pm |
Water shouldn't come out the rear when the end button is pressed.
Tue Sep 13 2016 6:15pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Yes, it's the same pump running in different directions for the front/rear. The button on the stalk should be for the front, so there must be an electrical issue somewhere - with those results it must be either with the switch, or wiring from the switch to the CJB (passenger fusebox). I think your symptoms rule out any issue with the pump/pump wiring so keep the bumper on. Visiting from DISCO3.CO.UK
Tue Sep 13 2016 6:18pm |
Will try electrics reset, will also do scan first just to see if anything comes up. |
Tue Sep 13 2016 6:21pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4970 |
That's quite strange on my facelift push the button operates rear washer, pull the stalk operates the front washers. Cheers Col |
Tue Sep 13 2016 6:32pm |
Just read codes and came up 1) battery saver relay output circuit B1C62-14 & front windshield wiper fast relay coil circuit B1C76-14 cleared them & front washers worked for couple seconds then stopped again, read codes again and no codes present, |
Tue Sep 13 2016 6:40pm |
On the early ones the button is for the front |
Tue Sep 13 2016 6:41pm |
May need a few cycles for the codes to return.
Tue Sep 13 2016 6:43pm |
Yes all settings work on wipers, disconnected battery for 10min, no joy, if I hold washer button all I hear is motor (& rear washer pumping out water) but if I blip the button ( on off on off continues) it squirts a little bit from both front, I can also hear fuse box clicking away on every press.
Tue Sep 13 2016 7:20pm |
Clicking could be a relay, might be worth checking and see if you can swap it for another one if there is one the same.
Tue Sep 13 2016 7:36pm |
Thanks will give that a check, if not obvious witch relay is wiper/washer shall I just do it by process of elimination. Remove relay try washer button and so on until I hear no click on pressing washer. |
Tue Sep 13 2016 7:46pm |
If you get someone to operate the stalk and you put your finger on various relays you may be able to feel which one is clicking.
Tue Sep 13 2016 7:52pm |
Great, thanks col. Will give that a go. |
Tue Sep 13 2016 7:56pm |
