![]() | Home > Technical > Turbo Actuator stuck |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
I am pretty convinced my passenger side turbo actuator has stuck, it did the same thing last year, before I book it in to get it look at, how hard is it to reach without a 4 post ramp?
Sounds a possible solution Neil, hopefully permanent. |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
Mine was no power ok when cold or once warm but if if was turned off it was powerless un till cool
You get a engine management fault on the display, and pulls away like a 1980's Skoda 😊 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
Thanks for the replies, never had this happen yet, so just wanted to be "aware" thanks. |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 ![]() ![]() ![]() |
I thought is read somewhere that from 2007 the actuator is operated several times every time he ignition is turned on and off to keep it moving freely, I can here some movement behind the heat shield in fns wheel arch when ignition is cycled which I believe is the actuator Nanocom Evo |
Funnily enough, i have just cycled the ignition 10 times and we are back to full power with no engine management light on, i drove round my estate on tickover and everything was fine, I booted it on the main road and got the warning message back up, I turned it off and on again another 10 times and so far it hasnt come back, went from zero to 40 away from the lights in sport mode, it reved through to about 4k before changing gear. A bit of black smoke from the exhaust, but apart from that were back on top 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
Fingers crossed, I'm losing power between 3.5 and 4K revs puts some Revive through air intake to try and clean turbo vanes which helped, having a terra clean tomorrow see if that helps, don't think the short journeys I do on a regular basis help.
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
I had a stuck actuator. £900 at main stealer prices to resolve out of warranty. Gah. But no further engine / turbo related issues.
