Home > Technical > Wobble
Stecla
England 2010 Range Rover Sport TDV8 HSE Stornoway Grey
Wobble
Hi guys,
In recent months I've had a few problems with my car notably rally hard ride and wobbly wheels since having its rear arc unit and propshaft replaced earlier this year. I took some advice on here and purchased a Iid gap tool and re-calibrated my suspension. I then took the car to elite wheels in reading for a proper alignment/balance.
The result is remarkable. The car is riding like a dream again, esp on motorways when is like a magic carpet. So all good. However, despite wheels being balanced a million times, I still have steering wheel shake/wobble at speeds approx 55/70mph both accelerating and braking. The front discs and pads were warped and changed a couple of months ago and have been checked and apparently ok. Since the re-balancing, the wobble is slightly better but still there.
I'm thinking that maybe a suspension component was damaged when my rear propshaft shattered back in march, but so far no one has found anything inc rob at rovertune who is pretty hot at finding this stuff. The wheels are new and not buckled and wheel nuts etc are tight.
Anyone got any suggestions as to what it might be? To be honest having sorted the ride I am less worried about this as I don't do too much motorway driving, but would like to get sorted so car is perfect again....
Cheers,
Steve 2010 TDV8
Post #504157 Wed Aug 31 2016 6:48am
SRE
Spain
I had this on mine, cured by new bushes and a steering rack. The beauty of Land Rover Warranty
There is a TSB for this LTB00400. This one was for NAS spec cars, so suited me as mine is LHD
You can find a copy in my gallery In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #504158 Wed Aug 31 2016 6:59am
Stecla
What's the approximate cost of a new rack? I have a good warranty, but unless the part has failed I suspect I will need to cough up for it (assuming that's the problem)... 2010 TDV8
Post #504264 Thu Sep 01 2016 6:08am
SRE
Spain
I think my Warranty bill was circa €3k In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #504268 Thu Sep 01 2016 6:27am
Stecla
I'll see what I can do. For that money, I may live with the wobble! 2010 TDV8
Post #504269 Thu Sep 01 2016 6:30am
SRE
Spain
So IF it failed the MOT then I Guess it would be covered. But first of all check all the wishbone bushes etc. The simple test I did on mine, have the car rolling along circa 5 MPH and jab the brake pedal on and off fiercely (short hard jabs) if you can hear any clonk or clang, then check all the bushes prior to going down the rack route. Thumbs Up
Best done with the radio off and without the Wife in the Car Rolling with laughter In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #504270 Thu Sep 01 2016 6:33am
Stecla
Thanks mate. Is in with Rovertune for a look in a week or so. I'll see what they say, but you are right that the best scenario would be to fail the mot as I have cover.... 2010 TDV8
Post #504271 Thu Sep 01 2016 6:35am
DrRob
Rob at Rovertune will know what's causing it Thumbs Up
Keep us posted Bow down Visitor from fullfatrr.com
Post #504277 Thu Sep 01 2016 9:08am
Stecla
I will indeed. Was looked at before by both him and Newbury 4*4 and neither could diagnose as all looked OK, nothing loose etc. Having said that, I was questioning my air suspension at the time too. Now that appears to have been resolved with a hunter alignment and suspension recalibration it only leaves this issue which may help, so let's see.
Interestingly I was speaking to rob a week or so ago as I was getting the wheels done and he has flogged his sport. Said it was having too many problems! He's driving a merc amg now, but fills you with confidence when the lr specialist won't have one.... 2010 TDV8
Post #504279 Thu Sep 01 2016 10:13am
Stecla
In with rovertune today. They don't know what it is. Apparently my front discs (recently replaced with pads) were very hot. Also they said they couldn't rotate the wheels freely when up on ramp. The new discs and pads I have are apparently aftermarket (fitted by Newbury 4*4).
Leaning towards some kind of binding, but no one seems sure. Being investigated further tomorrow. I asked about calipers, but apparently they seem OK....
Any clues at all? 2010 TDV8
Post #505191 Mon Sep 12 2016 5:53pm
Down&Dirty
Warped disks?
Heard of similar over on the D3 forum,with aftermarket disks Whistle Currently MY16 Disco 4 Mr. Green
Ex RRS MY13
Ex Discovery 3 MY08
Post #505197 Mon Sep 12 2016 6:39pm
Stecla
My thought too, but less than 2k miles? The ones before were warped too but were genuine. Could that be indicative of another issue?if it is warped discs I guess I need to foot the bill as let them fit aftermarket ones (not that I knew, I assumed Newb 4*4 used genuine parts)....
Let's see what they say tomorrow! 😥 2010 TDV8
Post #505200 Mon Sep 12 2016 6:47pm
DrRob
Hope it gets sorted soon Bow down Thumbs Up Visitor from fullfatrr.com
Post #505247 Tue Sep 13 2016 8:52am
Stecla
On way to pick up. New (proper) pads and discs and a good clean of various bits filled with grease. Will report back, but am so used to being disappointed and problem still being there that I darent get any hopes up! 2010 TDV8
Post #505313 Tue Sep 13 2016 5:37pm
Stecla
Just got back. Much better. No wobble on light braking and much less vibration on acceleration. So all in all, expensive but worth it.
When I got back the brakes were pretty hot though despite the fact I am relatively light on them. So am going to give a week or two as the aftermarket set were fine for a few weeks and then went all wobbly.
All in though, a happy camper for now!
Cheers,
Steve 2010 TDV8
Post #505333 Tue Sep 13 2016 6:57pm
