Home > In Car Electronics > Reverse Camera Lines - Predictive?
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
I have the static yellow lines displayed on the screen when reversing in my my13 RRS1. When looking at so many pictures of RRS's online when buying, I noticed that some were the static yellow lines, and some were the white lines that moved according to your steering wheel position in a 'predicting where you will end up' kind of way. From what I gathered it was the newer ones which had the white predictive lines, so as my RRS1 is a MY13 (built 09/11/12) then I was kind of expecting the white lines. Did this come later, or do I need to turn it on?
Thanks. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #502604 Thu Aug 11 2016 5:32pm
Had a feeling you only had the "bendy Lines" lines on a RRS1 if you have the surround camera system fitted, could be wrong though.
Post #502612 Thu Aug 11 2016 6:20pm
insiorc
Thanks Col
I've just been looking at autotrader trying to find them again and I can't, even on the dual screen ones so I was starting to doubt I'd ever seen them (I'm sure I have). But that makes sense if it was the surround camera ones.
Dennis 13MY Range Rover Sport Autobiography SDV6 - mine
Post #502614 Thu Aug 11 2016 6:28pm
No you have certainly seen them as I have them, but I do have surround cameras and dual view but don't think that has anything to do with them.
Post #502618 Thu Aug 11 2016 7:41pm
Russben
Did I read somewhere on here that you can enable the 'bendy' lines by putting it into reverse then pressing the screen to change between static & dynamic lines?
Mine is a 2010MY so it only has static lines, so I couldn't tell you if this works. I'm in the shed, I'll be back in the real world in a minute.
Post #502685 Fri Aug 12 2016 7:17pm
This is purely a guess and the "bendy lines" are part of the Surround Camera option which also includes the Tow Assist Facility, now even if you don't have the surround cameras it might be possible to activate Tow Assist in the CCF Files and it give you "bendy lines" I don't know it is only a thought.
I already have it so can't try it on my car or else I would, if I get time will switch it off to see it disables the bend function, perhaps somebody else that has the Gap tool but only straight line could try.
Post #502687 Fri Aug 12 2016 7:46pm
Johnski
I have straight and dashed lines or either side of screen view, but think that's just standard view? Neutral
No difference using the GAP IID BT tool to turn other options on/off as suggested, but I don't have the surround cameras on 2012MY. John
Post #502694 Fri Aug 12 2016 9:00pm
John, when you activated Tow Assist in the Configuration files did it do anything like give a fault or message saying anything about this option not being fitted or something to that effect or was the option not even listed in the files.
Post #502712 Sat Aug 13 2016 9:12am
Johnski
Hi Col, It was listed in config files, but on trying to turn on, it did "inform" me that the function isn't fitted, and so nothing was switched on. Was going to give GAP a call next week to check if I'm doing it correctly and if anyway to switch options on that aren't fitted basically. I have a FBH fitted, but although it allows me to set up for timer etc, nothing is shown or happens which is also strange. But when my timer unit is fitted I will see where I went wrong in turning on.
I've had no problems altering height of air suspension and several other features that dealer had never activated, so it's strange some things are not "allowed" to be actioned.
Incidentally, my solid and dashed lines on Park assist are in White colour not yellow as main post indicated, could be due to year, hadn't realised till I checked properly. Whistle John
Post #502759 Sat Aug 13 2016 8:00pm
Hi John,
Yes that's the message I was thinking of, ah well worth a try I suppose.
Post #502761 Sat Aug 13 2016 8:35pm
tonywolf
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
Morning all, Bodsey may well know if it's possible to enable or retrofit Tow Assist👍 Best Regards
Tony
MY2014 SDV6 AB Dynamic
Post #502773 Sun Aug 14 2016 3:45am
tonywolf
Tony
Post #502774 Sun Aug 14 2016 3:46am
